Re: 340 utility
Posted by mattofvinings on June 18, 2009 at 16:45:53 from (198.208.159.20):
In Reply to: 340 utility posted by mattofvinings on June 18, 2009 at 10:01:41:
Thanks Hugh, the only basic change I can see from reading/searching is that the 340 has a 7.6:1 compression ratio vs. the 5.?:1 ratio of the older "C" iron.
While that change might be partly done with a new cylinder head chamber design I'm not so worried about the head....its the block and crank depending on what got trashed during this low-lube event I've heard about. If it is as simple as getting a good SC block and lower end and using the 340 sleeves, rods, pistons and head, I'm there :).
