Posted by Hugh MacKay on June 18, 2009 at 19:27:27 from (209.226.106.66):
In Reply to: Re: 340 utility posted by mattofvinings on June 18, 2009 at 16:45:53:
Matt: While the block is the similar, it uses 14 head bolts rather 9 as in C, SC, etc.
The 340 uses thiner sleeves giving a 3-1/4" bore compared to 3-1/8" in Super C. The crank and rods differ in that stroke is longer, so larger swing on crank and shorter rods. The crank rods and 3-1/4" pistons will fit the Super C block, but you'll require a 9 bolt head.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
