Posted by Janicholson on June 18, 2009 at 16:55:32 from (66.173.50.162):
In Reply to: Re: Farmall M. 1948 posted by Bob Lanford on June 18, 2009 at 12:45:45:
The seal is easily changed. caseih.com choose your country, then select parts and service tab with pull down menu. select parts. on the next page choose "begin your search here". in the box put Farmall then scroll down to M then choose chassis then choose transmission The clutch pictures may also help. This gives numbers and exploded views. Pull the Belly Pump. Take out three of the clutch pressure plate bolts (at 120 degrees from each other) this leaves 3 other bolts. Put these bolts into the back of the Pressure plate (there are three holes with threads) this releases the clutch (pushes in the fingers), and allows the clutch shaft to be removed. Remove the four bolts holding the drive coupling together. Take pictures of the assembly to assure reassembly in the correct orientation of the drive plate in this joint. Remove the clutch shaft (it will come out it is a geometric puzzle, but done quite often world wide! Now the retainer is easily accessed to change the seal.Many bearing and NAPA stores will be able to cross the number. Other directions are in the archives for removing the pump, (heavy and awkward) I hope this helps, JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
