Re: Farmall M. 1948
Posted by Bob Lanford on June 18, 2009 at 12:45:45 from (76.6.212.59):
In Reply to: Re: Farmall M. 1948 posted by Janicholson on June 17, 2009 at 20:08:19:
The seal I need to replace is in front of the transmission where the spline and universal joint couple. If I used the incorrect terms in my previous question, I appolize and hope you can help with this. Thanks, Bob Lanford
