Re: Generator charging questions update II stumped
Posted by Bob M on June 18, 2009 at 19:07:22 from (74.74.133.11):
In Reply to: Generator charging questions update II stumped posted by a_lead on June 18, 2009 at 18:42:43:
Edward - A couple quick things to try:
1 - Run a temporary ground wire between the sheet metal regulator base and the grounded battery post. If the generator now charges whatever metal part the VR is mounted to is not grounded well enough.
2 - Check the wiring between the VR "F" and the generator "F" terminals for continuity. Could be there's an open circuit in the field wire inside the harness.
Where did you purchase the VR? (I need a new one for my Super H and $47.50 is a good price...)
