I've put things away for the night (I'm on the east coast, should already be between the sheets!!). I did run a temp wire between the field post on the gen and the field term on the VR. No difference. VOM also said wire in harness is ok.
Will try suggestion 2 tomorrow.
Got the VR from tornholmsagservice dot com (Rusty Farmall) Thanks, Edward
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
