Normally I would say this is the typical stuck in two gears at once problem. However, 1st and Reverse are on the same slider gear.
You can't be in 1st AND Reverse at the same time unless something is really really wrong in the transmission.
Are you SURE that it's 1st gear you're shifting into? Could it be 3rd?
I guess it wouldn't hurt to try the stuck-in-two-gears-at-once cure. You need to remove the shift lever, and look down in the hole. There's three shift rails in there. Use a big screwdriver to pry all three back to center.
The ball on the end of the shift lever is worn after 60 years of use. You can build it back up with weld and grind it down to fit.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
