Posted by cazzhrdwd on June 19, 2009 at 17:10:02 from (96.234.155.61):
I got the spiner off my super M to look at the gears. I did'nt see any broken teeth and they did not look worn bad at all. Between the hydraulic reservoir and the trans housing the tractor is loose. There is two large bolts at the top that are tight, but as you go down the side there is a gap that gets larger. About a 1/16 of an inch at the bottom. I see two bolt threads coming into the trans housing at the bottom but it looks like I have to go through the hydraulic reservoir to tighten them up. My question is that the way to do it, go through the hydraulics?Also where can I get a gaskett for the spinner.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
