Posted by Janicholson on June 19, 2009 at 18:30:18 from (66.173.50.77):
In Reply to: pop in trans posted by cazzhrdwd on June 19, 2009 at 17:10:02:
The term spinner is not (in my history) associated with anything on the trans. I'll guess it is the belt pulley drive gear attached to the top of the torque tube. With that assumption, the gasket can be made, or purchased (CaseIH probably has them. Use the same thickness as was on it due to the fact that it is the method of setting gear clearance to the drive. The threaded components are actually dowels used for assembly at the factory, and afterwords when taking it apart. they will not tighten, they will just pull out. The bolts you actually seek are inside. Remove the cover plate to the rear of the belly pump (tin plate, no oil in there to speak of, it is a dry chamber). The bolt heads can be seen from there. I would jack the trans up to take out the gap then tighten the bolts. This is not a gasketed mating surface, so there is no gasket there. caseih .com select US, then parts and service then parts, then begin your search right here, then put in Farmall, then select M, then select chassis. Many pictures! JimN
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
