Re: H- Starter will not Engage
Posted by ewalker on June 19, 2009 at 17:20:34 from (209.132.170.69):
In Reply to: Re: H- Starter will not Engage posted by daniel gillespie on June 19, 2009 at 16:50:39:
Put in 5th and rocked it a couple of times and that done the trick, push starter switch started right up. Think the battery was little week. For the discharge, the alernator has 3 wires one is jumped back to the wire on the back and the third wire returns to the positive side of the starter switch.
