Re: H- Starter will not Engage
Posted by daniel gillespie on June 19, 2009 at 16:50:39 from (209.163.124.226):
In Reply to: Re: H- Starter will not Engage posted by Janicholson on June 19, 2009 at 07:00:17:
Hey a better solution that requires no tools. Put the transmission in 5th gear unlock the brakes and rock the tractor back and forth at the wheels. You should see the fan rotate back and forth should pull the bendix spring back and unlock the starter. Worth every penny of effort!!!!
