Re: Farmall Regular - Transmission/Axle Removal
Posted by Texas Swede on June 20, 2009 at 14:07:03 from (98.197.109.159):
In Reply to: Re: Farmall Regular - Transmission/Axle Removal posted by SproutW on June 20, 2009 at 07:12:20:
third party image
That photo is the disassembly point I am trying to achieve. I have unbolted everything that holds the transmission to the axle housing. At this point, All I need to do is remove the axles from the axle housing.
This photo is exteremely helpful. Thank you.
As I understand this, all I need to do is remove the two nuts that I have labeled in the marked up copy of your photo included with this post. Correct??
If correct, was it difficult to pull the axles once the nuts were loose? Was very much force required?
Thank you for replying.
