Re: Super H Carb question
Posted by Janicholson on June 20, 2009 at 16:45:22 from (66.173.50.15):
In Reply to: Super H Carb question posted by jonnny2006 on June 20, 2009 at 15:18:34:
Well fixing it might make it use more gasoline. There are plugged up passages in the carb. The high speed adjustment is actually an adjustment of added fuel. It does not control the main jet, it adds to and subtracts from its middle settings. Thus your tractor is running as lean as it would if the adjustable screw was all the way in. If you pulled it hard all day it might burn a valve, or cause other lean condition harm. JimN
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
