Super H Carb question
Posted by jonnny2006 on June 20, 2009 at 15:18:34 from (66.44.162.148):
Super H will not start unless the throtleis all the way down. Also once started runs perfect at higher speeds. When i go to adjust the high idle jet it DOES NOT make a diffrence if i turn it ALL THE WAY IN or ALL THE WAY OUT. I never seen one run when you turn the high idle jet all the way in. How can it not make a diffrence nomatter where i adjust the main jet? I even took it out and put my finger over the hole and it ran the same no diffrence. It just starts hard and only with the speed all the way down. Got good gas flow,and i can run it all day wide open and it dosent run out of gas.
