Re: Farmall Regular - Transmission/Axle Removal
Posted by J.J. from Afton on June 20, 2009 at 20:07:55 from (66.41.82.17):
In Reply to: Farmall Regular - Transmission/Axle Removal posted by Texas Swede on June 19, 2009 at 21:50:21:
Yes those four bolts are for holding the packing in place. As for the axles the only thing that holds them are the 3 botls going through the circular plate as shown here in Sprouts photo. But since you have everything else but the shafts and casting off the shafts should just pull out, as there is nothing holding them from within the center by the ring gear. And they should not be all that hard to pull out unless the arent being held level as you pull or something. Do the shafts wobble fairly easily or are they a tight fit into the differential? If so they should just pull out without an enourmous amount of effort.
third party image
