Re: 1066 TA high side not working question
Posted by Janicholson on June 21, 2009 at 05:04:51 from (66.173.50.176):
In Reply to: Re: 1066 TA high side not working question posted by pete 23 on June 20, 2009 at 21:22:47:
I'll add to Pete's good info that if it has the light working correctly, and pressures check, and the Hydraulic clutch controlling (stopping freewheel in TA low) then the high TA clutch can be worn out, or possibly hemorrhaging. If that clutch is the issue, and the pressures are OK it is still a good Idea to fix it, as parts roaming around in the Hydro System cause issues beyond financial recovery. JimN
