Re: 656 shifter
Posted by pete 23 on June 21, 2009 at 19:12:58 from (173.87.14.132):
In Reply to: 656 shifter posted by hardscrabble on June 21, 2009 at 16:47:57:
Ya, the pin works out then you can't cross shift. Earlier models had a round pin, kit had square. They also changed the gates from one piece to seperate pieces. If you can see end of pin and drive it back to a centered position you may get by for a while. They are not much fun to work on but if you do it all correctly they shift much better.
