The pump has two simple gears inside. The end play of these gears is a very tight tolerance against the cover plate. (as discussed above) The covers warp (they are not cast iron) and leak substantially when they do. Flat sand the cover to take out the warp. use 250 grit on a piece of flat glass, in a circular motion, then as it just gets flat, use 400 grit paper. When putting the cover on, the pump is free to turn. Use a gasket combo (caseIH) that is close to the original gasket. Shim material can be purchased from NAPA or others. You will need .0005" and .001" brass shim stock. Put a small piece of .0005 shim stock (about half a penny in size)between the end of the gear and the cover. As you tighten the cover evenly and carefully, keep moving the shaft a little. If the cover can be tightened pretty tight, you know it has more than .0005" clearance if it still turns. Now use the .001" stock, (take out the .0005) and again tighten slowly and evenly. If it now locks up before the bolts are snug, the clearance is less than .001". Pull the shim out and you can put it together. If it does not get stuck. the gasket is too thick, or too many (they are very thin). If it gets stuck with the .0005" shim it needs to be thicker. I hope this helps. caseih.com has a parts diagram for the gaskets, and look the part number up for a Farmall then select 400, then select engine. JimN
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
