Posted by Jim Allen on June 22, 2009 at 07:55:39 from (209.173.160.22):
I hope someone can help me understand why something happened.
The shaft seal in the bottom cover for the trans brake on my 826 was leaking. Draining is more like it! Not knowing if it was good or not, and not wanting to have the tractor down, I bought a new brake pad. As it turned out, the old one was probably 50 percent worn, so I replaced it. Anyway, now that I have the tractor back together and the linkage readjusted, it's shifting much better than before.
In particular, I was having trouble occasionally going from a forward gear to reverse... it would kinda stick between gears and not move. I would shift back to a forward gear, go forward a foot or so and go back to reverse and it would be fine.
Now, that problem is completely gone and the shifting to high, low and reverse, as well as the four speed ranges is much, much better.
I'll take all the positive results I can. Would just like to understand this one better. My only thought was that the clutch/trans brake were out of adjustment but I don't understand how they could effect the forward/reverse problem I was having. Ideas?
This post was edited by Jim Allen at 07:56:29 06/22/09.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
