Re: 826 Shifting Issues Resolved but Don't Know Why
Posted by Owen Aaland on June 22, 2009 at 16:28:00 from (65.165.246.54):
In Reply to: 826 Shifting Issues Resolved but Don't Know Why posted by Jim Allen on June 22, 2009 at 07:55:39:
A transmission brake that was set too tight can cause hard shifting like that. Shifting from forward to reverse or reverse to forward involves moving two different shift collars. A transmission brake adjusted too tight may not allow the countershaft to move enough to align the next collar after shifting out of the first. A confirmation of that would be if the tractor would shift if you released the clutch a little bit. That would release some pressure on the transmission brake.
A TA dump valve not correctly adjusted will cause problems getting out of gear or double shifting when releasing the clutch with the TA in the forward position.
