Re: more 574 lube pump inf.
Posted by Bernard le mecano on June 22, 2009 at 16:33:51 from (75.158.246.207):
In Reply to: Re: more 574 lube pump inf. posted by ohio dick on June 21, 2009 at 20:21:05:
Hi, the steering wheel turn by itself, but not the front wheels? Did the steering wheel is hard to turn, when the engine running? In the steering valve, it have 2 spring to center to neutral the valve, if you turn slighty the steering wheel on both side, did the spring return the steering wheel to neutral, check with the engine stopped. Bernard le mecano Quebec Canada
