Re: more 574 lube pump inf.
Posted by ohio dick on June 21, 2009 at 20:21:05 from (4.131.42.214):
In Reply to: Re: more 574 lube pump inf. posted by Bernard le mecano on June 21, 2009 at 07:36:39:
pto works ok checked pressure was low shimed up to 250 psi. did notice that stearing was placing a load on hydraulic pump unless you would very carfully hold stearing wheel if you let it go it will turn slightly to the right and load pump but not enogh to turn front wheels.
