Posted by Janicholson on June 22, 2009 at 20:51:11 from (66.173.50.19):
In Reply to: Re: M Stuck Valves posted by RickA on June 22, 2009 at 18:56:28:
They will not be bent, there is nothing to hit at all. They can be lubed up from the top with penetrating, not WD40, oil, then tapping on them will begin to loosen them up. If you end up taking the spring off, put a 2' piece of rope in the cylinder, and move the piston up (by hand crank, not starter) to hold the valves in place. The pushrod (unless cracked) can be straightened out on a good block of wood (carefully) then roll tested for straight. No issue at all, they will be fine. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
