Re: M Stuck Valves
Posted by RickA on June 22, 2009 at 18:56:28 from (65.80.73.120):
In Reply to: Re: M Stuck Valves posted by Bob M on June 22, 2009 at 10:40:47:
We puled the Valve Cover & guess what ??
We found both #2 & #3 Exhaust Valves Stuck...
The #2 Exhaust has bent the Pushrod, and #3 Popped out of the Pushrod..
Not sure yet if we have bent a Valve or not,hopefully not.
Seems like you have good access to both Valves thru the Sparkplug Hole.
Once the Valves are Free, might be able to Rotate them to see if they are bent??
Should be able to hold them up to Replace Valve Springs/Caps & Retainers if not bent.
Appreciate All of your input..
Thanks Guys
RickA
