Re: Super h and M carb Diffrences?
Posted by Drill bit on June 23, 2009 at 16:01:16 from (4.224.78.27):
In Reply to: Super h and M carb Diffrences? posted by jonnny2006 on June 23, 2009 at 14:09:56:
Save yourself the headache from the smell of cleaners, get some numbered drill bits, clean passages in the bowl. Take a .080 drill bit, run it thru the main jet (remove discharge nozzle first) blow ou the shavings, reassemble, and you will have more fuel out of your Super H carb. Venturi for the SH is a 23, a 25 is in a M. That main jet in your Sh bowl is probably around .050, its hunting, becuase its running off BOTH the idle circuit and the main jet, it takes a bigger sip off the idle, cause the main jet isnt big enough, its swapping circuits back n forth. seen this 500 times or more! I bet if its clean, there is nothing wrong with it other than needing a bigger jet size
