Super h and M carb Diffrences?
Posted by jonnny2006 on June 23, 2009 at 14:09:56 from (66.44.162.148):
i know the choke is on the other side, but as far as the insides go are they the same or does the M carb supply alot more gas. Reason i was asking i put the super h carb on my M and it started up but the same prob occured when i put the SH carb on the M. High idle circut cannot be adjusted, and as a result the engine "HUNTS" when you crack the gas open fast. I will go to town and buy a gallon of carb cleener and will let it sit in there for a few days and then i will blow all the ports out again.
2nd question, can i take the bottom part off my M carb and attach it to the top part of my SH carb to see if the prob goes away, or are they diffrent? Thanks to all that are helping.
