Re: Super A carb rebuild questions (Carter)
Posted by ShaggyM on June 24, 2009 at 06:48:16 from (173.23.152.249):
In Reply to: Super A carb rebuild questions (Carter) posted by Fred Miller on June 24, 2009 at 04:56:22:
I have had decent luck rebuilding them but its time consuming. The big thing I ran into was the pot metal bowls were warped and it was a bugger getting the air bleed jet out of the top of the bowl so I could flatten it out. As far as gaskets go I made my own out of thicker gasket paper and they have worked so far. I have 6 yrs on one for my Super A. I alway shut the gas off because Dad got me in the habbit of it when I was a kid.
Shaggy
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
