Re: Super A carb rebuild questions (Carter)
Posted by Fred Miller on June 24, 2009 at 07:15:11 from (162.83.71.157):
In Reply to: Re: Super A carb rebuild questions (Carter) posted by ShaggyM on June 24, 2009 at 06:48:16:
Hi,
I always shut it off too because my father-in-law did. Those guys really knew their stuff! I will continue their wise habits!
Fred
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
