Jonnny I'm a little confusued. (nothing new) In your first post on the subject, you said the tractor was hard to start but would run good at wide open throttle all day long. If thats the case the high speed circuit of carb must be okay. Also you didn't indicate if partially closing choke while running helped or hurt any of your problems. Your carb may be the problem, but don't limit your checking to just it. Have had some that started hard like you said but would run fine that had a ignition problem. Also one with same problem that changing the aftermarket manifold cured the problem. Could have leaked at gasket surface or another problem, I just changed it. If it doesn't help the problem when choke is closed some, I would suspect your getting to much fuel or the ignition system isn't up to parr.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
