LiftAll Pump removal on F20
Posted by BruceS. on June 24, 2009 at 12:56:01 from (76.15.46.133):
My F20 is leaking transmission gear oil into the LiftAll pump. I'm assumming, I hope correctly, that the seal behind the drive mechanism in the pump needs replacing and that means removing the pump. Question: will the pump drop out by removing bolts holding to the mounting plate? It's an M pump with the T shaped drive couplings. There is almost no room between the pump and the bell housing so it would have to come straight down. Any advice appreciated.
