Re: LiftAll Pump removal on F20
Posted by Andy Martin on June 24, 2009 at 13:37:16 from (199.197.2.142):
In Reply to: LiftAll Pump removal on F20 posted by BruceS. on June 24, 2009 at 12:56:01:
Be sure to line up the coupling so one groove is vertical to allow the pump to come straight down.
The tee to go in the lower holes is eacy to build, just weld a ear on it to fit the slot and a handle on the other end so you can tilt the pump as required. It is easiest with two people and a bear with one person and no jack but it can be done. I've never tried the all-thread method because I have T handles.
