Re: F-20 clutch experts - - phase 2
Posted by Slowfolk on June 25, 2009 at 06:46:39 from (69.24.189.128):
In Reply to: F-20 clutch experts - - phase 2 posted by Pete in Holland, MI on June 24, 2009 at 15:47:14:
The clutch on my F20 also has two springs per hole. This allows for more tension on the clutch plate. When dissassmebling the clutch there are three threaded bolt holes to install a bolt to release the pressure and dissassemble the pins. Then the bolts can be removed equally to relive the pressure on ther springs.
