Posted by Wardner on June 26, 2009 at 19:17:56 from (4.154.241.134):
In Reply to: MTA hydraulic pressure posted by Agco Avenger on June 26, 2009 at 16:27:32:
I run three spool valves on several of my SMTA's. Plumb the inlet of your spool valve to the pressure port that points left and is at the top of the three port group. I believe the other two ports are for "delayed lift" and may be affecting your pressure. I have never used those ports.
Let us know how it works out.
Jim is right about the pressure. If you are trying to lift modern equipment, you may have to replace the existing hydraulic cylinders with larger units. If you double the calculated square inches of the piston, you should have no problems with late model implements. There is no need to double the diameter as that will give you four times the lifting power.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro
... [Read Article]
