Re: MTA hydraulic pressure
Posted by Wardner on June 26, 2009 at 19:47:48 from (4.154.241.134):
In Reply to: Re: MTA hydraulic pressure posted by Wardner on June 26, 2009 at 19:17:56:
One further note.
The Lift-All lever must be pulled back to activate the system. If you prefer to continuously activate the hydraulic system, there is a little tab on the reservoir near the bottom of the lever that can be rotated. It will keep the lever positioned to the rear.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
