Re: a couple of radiator questions
Posted by Rossputin on June 28, 2009 at 06:28:35 from (72.42.107.108):
In Reply to: Re: a couple of radiator questions posted by gene bender on June 28, 2009 at 05:48:23:
Hi Gene,
Thanks for the response.
I have to order the service manual so I can become more familiar with the parts and layout since I'm not sure what half of the things you mentioned are!
So, two quick clarifications:
I have what appears to be a hose coming from the radiator into a little thing which appears to have been a heater (just guessing) because it has cut electrical wires sticking out of it, and then there's a hose from there up into the block somewhere. Would I take that first hose off to drain the radiator?
And for the fan belt, I have to lower the top wheel it's attached to, not the bottom, right?
And where's the generator belt?
Sorry for the newbie questions. I'm ordering books now but I'd really like to get started!
Best,
Ross
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
