Re: Losing spark.
Posted by Brownie 450 on June 28, 2009 at 14:05:57 from (216.51.158.253):
In Reply to: Losing spark. posted by djone110 on June 28, 2009 at 12:31:42:
Scotty---if he has a generator from a 560, the brush/ commutator area is visible--at least our 560 had an open rear.
When the tractor dies, take a jumper wire with alligator clips & connect it between the battery hot terminal & the hot side of the resistor going to the coil. See if the tractor will start & run. This will eliminate all wiring from the battery through the ignition switch & up to the coil resistor. You likely have a connection or wire--even the ignition switch itself that is conducting when cold--& develops a high resistance when the engine is operating.
Don't overlook the new condenser being bad also.
