Losing spark.
Posted by djone110 on June 28, 2009 at 12:31:42 from (67.142.164.26):
Hello. I have a 1951 H that will run for ten minutes or so and then loses spark which leades to a stall or loss of power. I have changed the points, rotor, plugs, condensor and coil. This tractor has been converted to a 12 volt system. From the seat you can see into the back of the generator. There is sparking by the left side brush. At idle, I noticed the the brush stoped sparking as the motor tried to stall. Then I could see sparking in the back of the generator and the motor would pick back up. Could the generator be killing the spark? It has an external voltage regulator. Could this cause the problem? I have changed everything else. Thanks. -Dave Jones
