Re: M Farmall Idles Rough
Posted by Janicholson on June 28, 2009 at 15:07:24 from (66.173.50.18):
In Reply to: M Farmall Idles Rough posted by Grademan on June 28, 2009 at 12:31:36:
Denny's has not had a good following on this forum. Several issues. Don't count out that potential.
If it has a magneto, it will not have timing that is adjusted to the engine speed. It is full advance all the running time, retarded by the impulse coupling at start.
They do run a bit rougher and are harder to tune smooth. Does the idle mix screw have any effect?
JimN
