Re: Losing spark.
Posted by Doug - Iowa on June 28, 2009 at 18:02:34 from (208.126.1.102):
In Reply to: Losing spark. posted by djone110 on June 28, 2009 at 12:31:42:
Lots of great advice below but I'll add my 2 cents. My H has the distributor that sits upright, not on its side like many do. I was having lots of problems that seemed to indicate bad spark but just couldn't figure it out. Tried all the usual stuff. Then I took the distributor out to check bushings etc and found the bevel gear worn out. Replaced that and problems solved. So if you've to that type distributor, be sure the bevel gear is good.
