Re: Losing spark.
Posted by El Toro on June 29, 2009 at 05:38:47 from (205.188.116.73):
In Reply to: Losing spark. posted by djone110 on June 28, 2009 at 12:31:42:
You need to see what your charging voltage is at the battery when its running, check the battery voltage again when it quits. You may need to have that generator checked for voltage output.
If its not charging around 14 volts you won't have
enough voltage for your tractor's ignition. A low voltage problem when you have a mag doesn't need battery voltage. Hal
