Re: Super mta
Posted by JMOR on June 29, 2009 at 12:59:20 from (72.181.158.237):
In Reply to: Super mta posted by Bob M on June 28, 2009 at 17:54:53:
D Slater said: (quoted from post at 15:53:26 06/29/09) Serial # tag should fall from 60001 to 83523, unless its a diesel it should have a C 264 engine. Depending on the tractor serial # the original engine serial # should be between 113387 to 136833. Rare to find a original one with date codes later than september of 54. Some have some 53 castings on them. Never saw one with a casting earlier than july of 53. There could be though. make sure the hood is longer than a SM or M and that it has braces and the heat shield on manifold side underneath. Could be or may not be a tip off that its modified.
Braces? Please elaborate.
