Re: Super mta
Posted by D Slater on June 29, 2009 at 15:00:15 from (71.164.53.42):
In Reply to: Re: Super mta posted by JMOR on June 29, 2009 at 12:59:20:
Gas hoods had a brace on each side from the top to sides on the underside. MD and SMD used hoods the same length as SMTA but had no braces like that. Some times the hoods are used on SMTA gas by filling the exhaust hole on right side and making a hole on right. Sometimes the lower edges are left alone and that makes them easy to spot. Still the tractor could be a original that just needed a hood, but sometimes not. Back before SMTAD became collecter tractors some were switched to gas engines when the diesel went out and diesel hood was retained also. Noticed you didn't list letter date code U along with W used on some 51 models.
