If that battery has 3 cells its a 6 volt battery. If it is a 6 volt system you need to have your generator and regulator checked at your local repair shop that does alternators, starters & generators. If the battery has 6 cells its a 12 volt battery, but charging at 13.7 & 19 volts is too much for your battery. For a 6 volt system it should be charging around 7.25 volts & 14.5 on a 12 volt system. Hal
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
