That sure sounds like a bad ballast resistor. You can buy a 12 volt coil from Napa with a builtin resistor for around $18.00. Their p/n is IC14SB. Run a new wire from the battery to the - terminal on the new coil & reconnect the wire to the points. Then see if it will keep running. If it does then run the new wire to your ignition switch & then to the coil. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
