Matt - Most likely replacing the 6 volt regulator will have your tractor charging again.
Reason: If the "burned out" regulator has failed open on in cutout circuit (a common VR failure) the generator is now operating open circuited. And open-circuited, a healthy 6 volt generator can develop 12+ volts at idle and 20 - 25 volts at governed RPM.
You might try this: With a known good battery connected and and the engine operating at governed RPM temporarily jumper the GEN and BAT terminals at the VR. If the ammeter shows a strong charge (10 - 15 amps) when the terminals are jumpered a new VR will solve your problem.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
