Re: Checking/Setting Timing for a IH 544I C-200 engine?
Posted by spring lake farms on June 30, 2009 at 08:49:40 from (67.209.79.99):
In Reply to: Checking/Setting Timing for a IH 544I C-200 engine? posted by Eric Kaltenbach on June 30, 2009 at 08:23:57:
Does it run ok when at an idle or does it miss? If it runs ok at an idle it sounds to me like there might be an issue with the govenor. Can you unhook it and run the throtle without it?
If it misses at an idle recheck the plug wires for the proper firing order which will be listed right next to the distribtor (1-3-4-2). #1 Cylinder is usually in the top-right hole on the distributor cap. Rotor turns ccw.
3 1
4 2
location on cap noted above.
Also make sure you have adequate fuel flow to carb. Lines free and clear of debris and new fuel filter.
good luck
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D ... [Read Article]
