Re: Checking/Setting Timing for a IH 544I C-200 engine?
Posted by Eric Kaltenbach on June 30, 2009 at 12:07:04 from (65.215.14.1):
In Reply to: Re: Checking/Setting Timing for a IH 544I C-200 engine? posted by spring lake farms on June 30, 2009 at 08:49:40:
As far as fuel flow to carburetor it is good. I do have the original owners manual but that really doesn't give me much information especially the governor. Where would the governor linkage be? I am really not sure if it misses but it does make a whistling noise and gets some carbon or dark smoke out of the exhaust. I have messed with the throttle linkage on the side of the carb but it doesn't react only shuts off when the butterfly closes. I have turned the idle screw completely to bottom and turned out 4 full turns and still nothing. There is a needle valve on the bottom of the carb where the solenoid run on shut off is normally. I can turn this all the way in then all the way out that fuels runs out but still nothing.
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D ... [Read Article]
