544 water pump
Posted by JerryinPa on June 30, 2009 at 16:34:02 from (75.220.188.12):
I just installed a new radiator and filled it up. I noticed a steady dripping coming from appears to be the front of the water pump around the shaft on the fan side, at least thats where it appears to be coming from (hard to really see in there). Any idea how much a replacement water pump is and where you can get one? (dealer, auto parts store, etc)
Thanks
