Re: 544 water pump
Posted by Trent544 on June 30, 2009 at 18:44:51 from (166.82.246.61):
In Reply to: 544 water pump posted by JerryinPa on June 30, 2009 at 16:34:02:
Try to find an OEM water pump, new or remanufactured. I bought a new aftermarket water pump from A&I and had to grind away a lot of cast iron to make it fit. The bearing didn"t seem as tight as I would like either. Most aftermarket parts now come from China and are a very poor fit. I would pay three times as much for an OEM part any day. It"s worth it in the long run. I also had problems with an A&I radiator in my 544. If I had it to do over I would have had my old radiator re-cored, even though it would have cost more than the new one.
