Well, I did use silcone when I originally put it together and the gasket kit came with a new grommet which I used. The only place it leaks is right at the cover at the grommet? What is the purpose of the gromet and hole in the plate behind it? The gasket has a hole in this spot as well.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
